06-16-2016
08:19 AM
- Mute
- Permalink
- Report
06-16-2016
08:19 AM
I think if you enable spiral moves you need this bit of code added near the top of the onCircular function.
if (isSpiral()) {
var startRadius = getCircularStartRadius();
var endRadius = getCircularRadius();
var dr = Math.abs(endRadius - startRadius);
//writeComment("Spiral move");
if (dr > maximumCircularRadiiDifference) { // maximum limit
linearize(0.01); // or alternatively use other G-codes for spiral motion
return;
I think it need to go just after the compensation check.
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
Mark
Edit you need to comment out the writeComment line like this.
Mark Hughes
Owner, Hughes Tooling
Fusion
