rumpelstielz
299 Views, 1 Reply
weird surface pattern in parallel finishing simulation
i am preparing to cut a piece and the simulation gives me the impression that the toolpath is not even, here is how the simulation looks:
the toolpath looks alright:
but no way to know if there is a smoothness problem until cutting the material. Is this a known issue ? I find it highly confusing. There is a similar issue when using the toolpath smoothing options, there the preview of the toolpath lines seems not related to the machining results.
Are these known issues ?
GENERAL DISCLAIMER: if there isn't a file attached to my posts then there is a reason for it. wherever i can i will attach a file for troubleshooting.If no file is attached i will always try to explain as clearly as possible with illustrative screenshots. when i have an issue that can only be helped by attaching a file which i cannot share publicly i won't ask about it here.
jeff.walters
in reply to: rumpelstielz
Judging by the radius at the end of the part this could just be graphics. Please try changing to Fast (3-axis only). Then Extreme and see if the looks better.
Jeff Walters
Senior Support Engineer, CAM
