ege.gener
221 Views, 1 Reply
Turning Inside Profiling Problem
Hi everyone. I can't create inside profiling toolpath for this part (please check attached files). I have tried every option to no avail. I am trying to create a toolpath for red marked areas. Any help will be appreciated. Thanks in advance.
iporter6
in reply to: ege.gener
You will need to use "Turning Groove" and select "inside".  You will need a face grooving tool like in the picture below. It needs to be setup in that orientation (90 degrees).  There is also a "turning groove Finishing".
