robin_brouwer245
293 Views, 2 Replies
Best way to import traced images from Illustrator?
(This is a follow-up to one of my previous posts)
https://forums.autodesk.com/t5/fusion-360-support/adobe-illustrator-dxf-export-not-importing-properl...
So, in the end the solution @jhackney1972 provided worked for that particular context.
As he said it was a lousy export and such, so I have to ask: What is the best way to trace images? Should I trace them in Illustrator and Export to Fusion, or should I trace the images directly in Fusion?
I know there's probably a million ways to do this, I'm (and @sibejanSJ too!) just curious what is considered the best way to Trace an image for CNC Routing.
I have to add that sometimes the images we're tracing are quite simple (e.g. the presents in my previous post are children's drawings) but other times the images to be traced are quite complex and we don't have time to perfectly trace these point by point.
If you look at the previous post, you'll see that there were some errors (unconnected lines, etc.) in the design. Is there a way within Fusion to highlight all these errors which prevented me from extruding?
