I just ran out some dummy xyz moves to check the process and my idea.
G0 Z10
G0 X10 Y100
G0 X20 Y110
G0 X30 Y120
G0 X40 Y130
G0 X50 Y140
M0 DANCE PARTY
G0 X200 Y200 Z100
G0 X10 Y10 Z10
Worked fine. Did the moves, prompted me to click the jog wheel and started right back up.
Since fusion doesn't have the stop command baked in yet, I found the layer I needed to stop at and manually edited the g-code above layer 101:
G0 Z300 ;moves gantry out of the way
M0 ADD NUTS ;Marlin supports throwing a message in, so I did.
It's currently ticking along and paused where it was supposed to for adding nuts.
I attached the g-code, reference lines 37093-37094 for my additions.
I do look forward to seeing this process added in. While not onerous, it is a bit inconvenient and unfriendly.
