Benjammann
in reply to: leo.castellon
Yeah, I also currently export step files and import into fusion. The problem is when a change occurs I lose all my toolpaths. I've resorted to making the change in Solidworks and then also in Fusion if it's a small easy change. Or sometimes Ill just import one part from the sheet and replace it. A pain in the neck either way. Would be great if the assembly had a live link that worked so the parts could update and retain the paths.
