seth.madore
in reply to: conjured2018
This sounds like more of a machine and controller question, and not a Fusion question, unless I'm misunderstanding what you're asking...
Fusion permits setting a work offset anywhere on the part, but that work offset is going to be relative to your machine coordinates. Is it possible for you to adjust the home position at the machine, either mechanically (moving the home switch to permit center of motion homing) or digitally, by adjusting a parameter value, such that when you home it out, the position is now reading X-24 Y-24?
Seth Madore
