conjured2018
342 Views, 2 Replies
Homing and setting zero
I work in wood. I have a 4 ft x 4 ft bed on cnc. controller is DDCS V3.
I zero'd mill at near left corner for a long time. Now I zero at x24 y24 inch or dead center of 4 ft by 4ft board. i drill holes first and center is drilled. I then  can use a 1/4 inch drill to position exactly over and into hole if needed. this might be needed if I do not tab in right place and piece comes off and jams mill. this is bad and I go back to measuring both Ys and make same distance. I then can find zero by using drill method.
Ok, my issue is I can not home to 24x24. the back feature after home is only 99mm. I have always homed in past and now I cant. Even the left top mill position is not doable with my controller.
is there a way to be able to home to center of board? I do see offsets in parameter section of controller. this is a ddcs V3 controller.
I want to use homing sensors on x and y to get mill to center board. thank you JR
JR
