@dwilliamsFM6K4 . This is great feedback. I wonder if if the Flat toolpath is still inadvertently still interrogating more of the model behind the scenes than is necessary. DO you still get the time-penalty when you model up the geometry for machining separately ?
Be useful to see your original data set if you don't see a time hit with the only-required geometry.
Look forward to hearing back from you on this one. Thanks for the feedback
Kieran Gill
Technical Consultant
