JESwardstrom
210 Views, 2 Replies
2D Profile One Side of a Body
I am trying to plasma cut just the ends of a body, and I'm wondering if you can deselect edges or remove them from the order to get Fusion 360 Manufacture to cut both ends of a steel bar rather than cutting the whole periphery .  I am basically testing how to cut a slot and a tang that would fit the slot.  I also have a single line splitting the part that I would like to cut without kerf turned on, which is another tool path with a different cutter I'm thinking, but I have yet to try that.
engineguy
in reply to: JESwardstrom
@JESwardstrom
What you can do is to hold down the Alt key and then just select the edges/lines that you want.
JESwardstrom
in reply to: engineguy
I appreciate the tips.  That's just what I needed.
