FrodoLoggins
in reply to: kieran.gill
I don't like to use either. The new flat toolpath takes way too long to generate, misses parts of flat areas when finishing passes are specified, and doesn't have enough options to make it useful for me.
Options that would be nice:
- Repeat [wall] finish pass
- Multiple [wall] finishing passes
- Different feedrate for [wall] finishing passes
- Ability to take multiple depths of cut for finishing passes only
- Ability to take multiple depths of cut on the first finish pass but then 1 single (or a different amount) finishing pass on the second pass
- Ability to specify a minimum cutting radius
- Finish pass overlap/tangential fragment distance
- Outer corner mode (roll around/keep sharp)
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
