serge.quiblier
in reply to: lethal375
Hi @lethal375
Error 65 seems to be cause by the following situation
65 - ILLEGAL COMMAND IN G71-G73 (T series)
Alarm Description
1.) G00 or G01 is not commanded at the block with the sequence number which is specified by address P in G71, G72, or G73 command. 2.) Address Z(W) or X(U) was commanded in the block with a sequence number which is specified by address P in G71 or G72, respectively. Modify the program.
Can copy the gcode file to another file and hand edit it.
Then change the line N47 X4 to N45 G1 X4.
And test it again.
I don"t remember having this kind of trouble before.
The rest of the code look correct.
On an older controller, I would have questioned the G71 one line version against the two lines version.
But it's Fanuc 18, and that was more a Fanuc10/11 trouble.
Regards.
Serge.Q
Technical Consultant
cam.autodesk.com
