M&GToolWorks
in reply to: M>oolWorks
In fact, everyone can access an example. For whatever reason, Fusion will not let me share a link, but if you look at the bottom of the "Project List" under Samples, you will find Workshops & Events, Education, IMTS 2022, you will find TM-0 CAM ASSM_Current.
If you take a look in Manufacturing, Setup - Vise 4 Second Op, and open the setup, change the Stock Mode "From Solid" to "From Proceeding Setup". Regenerate the setup and take a look at the issues. Can you make stock from proceeding setup work? Can you make the adaptive clearing work? Can you get the adaptive clearing to recognize the components selected and not the proceeding setup?
It looks like they have derived, copied and pasted components. Should this be done differently? If so, how?
