10-06-2022
11:18 AM
- Mute
- Permalink
- Report
10-06-2022
11:18 AM
Hmmm, yes, looked at it again and agreed, it should work.
However it does work, I think your issue was making a copy of the first Contour with the 1/4in tool and then trying to in effect use the same Operation again, Fusion got confused I think, same here ![]()
I deleted the second (copied) Wall Operation and created a new 2D Contour and set it to "Rest Machining" from a preceding tool size of 0.25 and it seems to work as expected, I understand what you are trying to achieve by not doing the full Contour again, see the image below and attached file ![]()
Fusion
