10-06-2022
05:18 AM
- Mute
- Permalink
- Report
10-06-2022
05:18 AM
2D Contour: Rest machining not working?
As you can see in the below video after copying the original tool path with rest machining enabled and the disabling rest machining [on the copied toolpath] the toolpaths are exactly the same:
EDIT: Removing the Minimum Cutting Radius value of .01" allows rest machining to work but with .01" being so small that should have no effect here?
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Fusion
