ktorokU233T
in reply to: jscott6SWZG
@jscott6SWZG wrote:
I changed the tolerance to .001 and smoothing to 0.001 seems to have fixed up the simulations up
Simulation does attempt to give you a good perspective of how your tool path will look cut on the part. One of the limiting factors in how well it represents that tool path comes down to the graphics on the computer. One setting you may try and adjust is in the simulation pane that opens when you run a simulation.
It does help to turn the accuracy up thus showing a more realistic looking simulation with less pixelation and display artifacts. Keep in mind it also slows down simulations, sometimes drastically depending on the horsepower of your computer.
