10-03-2022
05:28 AM
- Mute
- Permalink
- Report
10-03-2022
05:28 AM
Hi @jscott6SWZG
It can be a post issue.
Are you using a post from the Autodesk library?
Have you tweaked it?
Can you share it?
Because i tried to post using the Rs274D post, and the partial rezsult is :
(spring copressor)
(Machine)
( vendor: Sainsmart)
( model: 4030 Generic 3-axis Router)
( description: Prover xl This machine has XYZ axis on the Head)
(T2 D=6.35 CR=0 - ZMIN=-18 - flat end mill)
N10 G90 G94
N15 G17
N20 G21
N25 G28 G91 Z0
N30 G90
(2D Contour9)
N35 T2 M6
N40 S27000 M3
N45 G54
N50 G0 X17.68 Y8.085
N55 G43 Z15.225 H2
N60 Z5.225
N65 G1 Z1.36 F508
N70 G18 G3 X17.045 Z0.725 I-0.635 F990.6
N75 G1 X16.41
N80 G17 G3 X15.775 Y7.45 J-0.635
N85 G2 X1.425 Z0.475 I-7.175 F508
N90 X15.775 Z0.225 I7.175
N95 X1.425 Z-0.025 I-7.175
N100 X15.775 Z-0.275 I7.175
N105 X1.425 I-7.175 F600
N110 X15.775 I7.175
N115 X1.425 Z-0.525 I-7.175 F508
N120 X15.775 Z-0.775 I7.175
N125 X1.425 I-7.175 F600
N130 X15.775 I7.175
N135 X1.425 Z-1.025 I-7.175 F508
N140 X15.775 Z-1.275 I7.175
N145 X1.425 I-7.175 F600
Some I,J values means that arcs are outputted. In fact, helix and arcs are mixed, as some have Z values, and others don't.
Regards
PS : I posted in millimeters, but it should not matter for the use of arc/lines.
Fusion
