09-13-2022
06:04 AM
- Mute
- Permalink
- Report
09-13-2022
06:04 AM
That`s OK, I didn`t know which Post Processor you were using, it is correct, the Tool Orientation is not supported in that PP.
So, I have removed the orientation and tested it with the Maho Phillips PP and it generates OK, just means that it cannot be simulated in Fusion but all you need is the 2D Contour and the correct setup at your machine as the tool is already at the correct angle all it has to do is go to the correct X and Z positions and then do the cut in the Y so it is down to your settings at your machine, try it now ![]()
Reckon you could do that easily at the machine control without Fusion
Fusion
