info63FGM
in reply to: engineguy
Hello
I got this error from your example
Information: Configuration: Maho Philips 432
Information: Vendor: Philips
Information: Posting intermediate data to 'C:\Users\desktop-006\Desktop\9501.nc'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1250  (ANSI - Central Europe)'
Start time: Tuesday, September 13, 2022 12:28:23 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5874.5
Configuration path: C:/Users/desktop-006/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/original maho philips 432.cps
Security level: 1000
Include paths: C:/Users/desktop-006/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Monday, September 28, 2020 11:46:03 AM
Output path: C:\Users\desktop-006\Desktop\9501.nc
Checksum of intermediate NC data: 2f7c2e5b3f60357849c0ef4f75dc330d
Checksum of configuration: 1cb158792cb69e92f566e7d49811fe19
Legal: Copyright (C) 2012-2019 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.13881
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error at line: 381
Error in operation: '2D Contour2'
Failed while processing onSection() for record 485.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, September 13, 2022 12:28:24 PM
Post processing failed.
I am not sure because I only work with 2.5D parts but I think that your examples makes the Fusion360 thinks it is a 4 axis machine. My machine is 3 axis but the head can be rotated manually.
