engineguy
in reply to: info63FGM
@info63FGM
OK, is the image below close to what you need ?
If so then it is just a simple 2D Contour with the "Tool Orientation" used to get the angle of the tool, I created a surface at 90 deg to the angled face to use as the Z face for the orientation to match the angle of your Head.
Modified file is attached, I used a nice big 16mm End Mill as I have no idea what tools you have :slightly_smiling_face: Feeds and speeds are up to you :slightly_smiling_face:
