- Mute
- Permalink
- Report
Gearsoup -
Thanks so much for taking a look at this. Indeed when I set the multiple passes to .150 and the ramping to .125 did allow the code to post properly. The strange thing is that it seems to be the .125 on the roughing that's causing the issue irrsespective of the ramping. Setting the ramping to .124 doesn't solve the issue, and in fact turning the ramping off entirely doesn't solve the issue. If I set the roughing to anything but .125 it seems to work (tried .150, .124, and .126). You definitely pointed me in the right direction, but I still don't entirely understand what the issue is - not a problem to use a slightly different value, but strange that .125 seems to be messing it up.
On the ramping itself - I think you're totally right that my setup is weird. It's not really what I want it to do, but I haven't quite figured out how to make Fusion do what I want. What I'm after is a ramp on the Z plunge so that if I'm using tooling that doesn't like to plunge cut that it will ease itself into the piece. Usually when I've done this in other software it's a little zigzag as it eases the tool in rather than a giant spiral around the piece. I don't neccesarily hate the giant spiral, but it does look like I'm duplicating some cutting.
Anyway - thanks again for the help! At least I can get functional code out now, even if the root cause still doesn't quite make sense.
Jason
Fusion
