engineguy
in reply to: info63FGM
@info63FGM
Are you looking to do something like the image below ? I am thinking the part will be setup to be cut in the Y direction ?
If so the try out the attached file, it is a simple 2D Contour with Multiple depths, I have done it this way because I don`t know how/if you have already removed a lot of the stock and only need a finish pass, if that is all you need then just disable the "Multiple Depths" and it wil just do a single pass at the surface, best I can do without your Model to work from.
I have set it up so that the passes are done in the Y axis so the table will move in/out on the Y, the position is moved in the X and Z to do the ;eft and right moves, so it moves to position in the X and Z, then cuts in the Y, moves again in the X and Z for the next cut in the Y and so on :slightly_smiling_face:
Hopefully it will be somewhere near to what you need, as already stated, best I can do without your Fusion f3d file.
Example file attached, open the file in Fusion and first run the Simulation and click on the "Info" tab and you will be able to follow the X/Y/Z moves, I generated some code here and it looks OK but not having the PP that you are using I am not uploading it as it is not likely to be correct for your machine :slightly_smiling_face:
