- Mute
- Permalink
- Report
Hi -
I'm hoping this is simple... I'm pretty new to Fusion, but I've been using it for a few months and have posted tons of g-code without any issues. This weekend I was putting together a batch of parts, and of the maybe dozen toolpaths, I had two that failed to post-process correctly. I didn't even realize until halfway through cutting one of the parts when my router just pulled out of the work and stopped.
Quick background:
I'm using a very simple 3 axis router and running it with Mach3.
The parts are dead simple 2d contours - pretty much just just a couple of circles. I exported one of the offending files - hopefully that works.
The CAM setup, toolpath setup, post processor, etc. are the same as I've been using on lots of successful parts.
The post processor is one that I downloaded - I think it is just a lightly modified version of the standard Mach3 post processor to simplify it a little bit. I just tested out a few post processors, and this one made my machine do less annoying things than the other post processors that I tried...
Here is the log that comes up when I try to post process the parts:
Information: Configuration: Generic Mach3Mill
Information: Vendor: Autodesk, Inc.
Information: Posting intermediate data to 'C:\Users\Jason\Dropbox\CNC\16.0604 - Fixed Dust Shoe\Clamp 1_4bit_4.tap'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, June 7, 2016 7:37:17 PM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 40504
Configuration path: C:\Users\Jason\Dropbox\CNC\0000 Setup\Post Processors\mach3mill_Chris.cps
Include paths: C:\Users\Jason\Dropbox\CNC\0000 Setup\Post Processors
Configuration modification date: Saturday, January 30, 2016 6:33:18 PM
Output path: C:\Users\Jason\Dropbox\CNC\16.0604 - Fixed Dust Shoe\Clamp 1_4bit_4.tap
Checksum of intermediate NC data: ee16a7c49d14d759892bb532e69dd982
Checksum of configuration: 17ddb58810cb48e1b38fd3aed8c5efa1
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2013 by Autodesk, Inc.
Post processor signature could not be verified (error 0xfffffffc).
Generated by: Fusion 360 CAM 2.0.2087
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Invalid toolpath point detected '(-1.#IND, -1.#IND, -1.#INF)' for 'onLinear'.
Error: Failed to execute configuration.
Stop time: Tuesday, June 7, 2016 7:37:18 PM
Post processing failed.
Any help would be greatly appreciated! I've been hunting around for similar errors, but haven't been able to find this. I'm guessing it's something simple that isn't set right, but I'm not finding where the issue is, and it's more disconcerting because all of my parts have worked fine up until now.
Thanks!
Jason
Fusion
