yd_kwon
in reply to: KonstF
The cycle starts at line 13, and the cycle changes from None to fine-boring.
And in the changed M3 code section, the existing operation is performed only when not fine-boring, so M3 in the lower part is not output.
To know the above, try outputting it to a dmp file. Then, you can see the function output order of the existing post file through the text file in *.dmp format.
It is true that it is easy to edit the cps file if you learn javascrpt.
Line 22 might be possible with a trick, but I don't recommend it.
Line 24 is unfortunately not editable. Now is.
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
