KonstF
in reply to: yd_kwon
Wonderful! It really took the M3 away after the spindle orientation. How can you comment on why it worked like that? Perhaps I need to start by learning Java script programming?
Modified the spindle orientation section - everything is correctly calculated. Thank you!
Tell me, in the 22nd line, you can also correct the feed to the maximum? And is it possible to get rid of excess movement along the X axis? 24th line
