yd_kwon
in reply to: KonstF
Test the code below.
  case COMMAND_START_SPINDLE:
    if(cycleType != "fine-boring"){
      // except fine-boring cycle case in Start_spinde
      onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    // origin code
    // onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
Your code can be modified like below.
function onOrientateSpindle(angle) {
  writeBlock("CYCL DEF 13.0 ORIENTATION ");
  writeBlock("CYCL DEF 13.1 ANGLE " + angleFormat.format(cycle.compensatedShiftOrientation));
  writeBlock(mFormat.format(19));//Used for oroenting the spindle for fine boring cycle
  onDwell(cycle.dwell);
CAM-Fusion 360/Inventor
CAD-Fusion 360/Inventor
Before PowerMILL
