JetForMe
137 Views, 0 Replies
Fusion 360 lost my machine definitions
I tend to use different parts of Fusion 360 sporadically. For example, I haven't run anything on my CNC router in months. But yesterday I needed to, and when I fired up F360 to generate some toolpaths, it had lost 3 out of 4 of my machine definitions, no matter how I adjusted the filters; it only had my 3D printer, but didn't have my three CNC cutting machines.
I tried searching my disk (macOS) for the files, and found my router in a folder (a subfolder of Application Support/Autodesk/.../W.login/...). In that directory is also one of my other .machine files, but neither shows up in the UI.
I was able to import the .machine file I needed into Manufacture and get up and running, but I don't know where that information is stored.
FEATURE REQUEST: provide a way to "Reveal in Finder" for all types of files that might be stored locally. It's really helpful.
In any case, it seems the file location for this stuff changed at some point, and the upgrade did a poor job of migrating existing files.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
