brad_francola
in reply to: bcdgroup.nc
This could also be an Inch to MM type of problem.  There may be a M or G code in the CNC program that the uccnc is having a problem with.  If each individual toolpath back plots correctly on your uccnc, then you should be able to make this work as one big program.  If you have a paid version of F360, there should be no limitations on the size/accuracy of the CNC program.
