HughesTooling
in reply to: mwoodzork
If you're using 2d contour with Compensation set to off you need a tapered mill.
For mutiple depths set the taper angle to zero, it will give a warning just click yes and ignore.
Mark
Mark Hughes
Owner, Hughes Tooling
