bcdgroup.nc
227 Views, 2 Replies
strange issue with fusion 360 and uccnc
Hi all
im using fusion 360 (that i buy for testing in 60$ / month) and uccnc software
my machine is stepcraft D840 -2
my issue is when i post process to uccnc with more the one tool operation (i.e.. 2D contour and holes drilling)
i see it in uccnc in very very small scale and spindle are moving much much slowly
if i post process with one tool operation (i.e..only 2D contour ) its all works fine
any idea what can cuz this issue?
maybe fusion360 license limitation?
Netanel.
brad_francola
in reply to: bcdgroup.nc
Hi.  It may be a good idea to backplot your code in NC Viewer.  That way you determine where the problem exists.  It is possible that the CNC code is fine and there is a different problem.
https://ncviewer.com/
brad_francola
This could also be an Inch to MM type of problem.  There may be a M or G code in the CNC program that the uccnc is having a problem with.  If each individual toolpath back plots correctly on your uccnc, then you should be able to make this work as one big program.  If you have a paid version of F360, there should be no limitations on the size/accuracy of the CNC program.
