DarthBane55
in reply to: Fabaaa
Oh I see, I think I somewhat understand (I've never seen worknc), but it seems like you can build your geometry kind of like we build a holder in Fusion isn't it.  So you'd work always in your master file, just update these numbers and you get your new updated toolpath.  That's the way I understand.
Maybe you can do the same, using parameters.  I am not sure, but say you put all your values in parameters in Fusion, and simply update those values, then regen, I guess it would be a similar result to what you are used to?  You can name your parameters too, so it's easy to find what is what.
Just an idea, not sure it works for you...
