- Mute
- Permalink
- Report
Need help - Fagor 8055 post processor edit for 5axis router
I've been tasked with editing a post processor for a fagor 8055 controlled 5axis router. I made a few modifications to the post which have worked well, but I'm struggling to figure out how to make this edit.
The post processor selects G17 as the workplane right after a TCP call. Then later in the code it calls G19 or G18, which causes issues as the tool wants to move into the part. However if we alter the G17 into a G19 or G18 manually this fixes the problem.
If somebody could point me in the right direction that would be great.
Relevant section of code:
// control uses D-word for length offset also
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 99) {
error(localize("Length offset out of range."));
return;
if (retracted) {
if (getProperty("fifthAxis")) {
writeBlock(dOutput.format(lengthOffset));
writeBlock(gFormat.format(48), "S1"); // Enable TCP mode after Work Plane if G53 is used for retract
forceXYZ();
gMotionModal.reset();
// set coolant after we have positioned at Z
//***setCoolant(tool.coolant); turned of fbecause machine doesnt use coolant
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted && !insertToolCall) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || retracted) {
currentPlane = undefined;
if (getProperty("useG16")) {
writeBlock(getG16("XY"));
} else {
writeBlock(gPlaneModal.format(17));
- Mute
- Permalink
- Report
Hello @freshhhhoi,
It is difficult to try to track all the arcs interpolations, and associated planes that may appear in a toolpath.
So, changing the G17 after the TCP activation seems nearly impossible.
The work around, if acceptable is to prevent the output of arcs in planes other than XY.
Linearizing all the arcs into lines segments.
At the top of the post we can find this variable initialization:
allowedCircularPlanes = undefined; // allow any circular motion
It can be changed to this definition
allowedCircularPlanes = 1 << PLANE_XY; // allow only XY circular motion
Hope it help solve your issue.
Cheers
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Fusion
