- Mute
- Permalink
- Report
Templates are good, and just in case you did not know, you can select all of your toolpaths in 1 shot and save them all under a single template. So when importing, you have them all at the same time.
If your parts are very similar, same features but different sizes, you can also copy the part. If you copy the part, modify it, and regenerate your toolpaths, they will conform to the new geometry, as long as you simply modified the sizes. That would be even more automatic because you don't have to reselect anything in the toolpath, simply regen.
You mentioned you use step files, so if you import every time, this won't work, but instead of importing every time, can you not modify the file yourself? You can use direct modeling to modify an imported model as well. So after the 1st part is programmed, copy it, modify the sizes, and regen toolpath, done.
Fusion
