Madcow2
in reply to: HughesTooling
No it did not.  Maybe I am not looking in the correct place but it just says "Error - Multiple Commands"
This is the beginning of the post that gives the error.
[1]
[T1 D=0.375 ball end mill]
G90
G20
[Parallel1]
M5
T1
G53 Z0.
S5000
M3
G54
G0 X6.0184 Y4.7316
Z2.4
Z-0.7792
This is the beginning post of a post that worked with no problem.
[1]
[T2 D=0.5 flat end mill]
G90
G20
[2D Contour13]
M5
T2
G53 Z0.
S1222
M3
G54
G0 X4.2625 Y0.2433
Z0.6
One out of many differences that I can see is the T value.  I use a good amount of bits so I do not have my library setup with different numbers.  All bits should be T1.  But that said the post that works says T2.  So I am very confused.
Is it the tool parameters that need to be changed?  But I have had successful cuts with this tool.
Also every time I run a program even after I use the top plate on the material it still goes over to the machines touch plate and remeasures it.  I would really like to disable the FTC.  Would this help?  When you are cutting many different parts with different setups FTC it seems not that helpful.  But then again I might not be understanding something.
Thanks for you quick response.  I have  a job half way done and am now stuck because of this error.
Erik
