engineguy
in reply to: jimMA3D3
@jimMA3D3
The finishing operation after the M00 stop is not set to the "In Control" option so therefore it is likely that the Post Processor is not outputting the "tool offset call", usually either a G41 or a G42, in your case it is likely to be a G42.
Without your specific Post Processor (I used the Doosan PP with Puma option) I may not have it exact but the image of the code shown in the second image does show that the "tool offset" is being "called" by the G42 line of code when the Finishing Operation is set to the "In Control" option, see images below.
Hope this is of some help :slightly_smiling_face:
Compensation set to "In Control" gives you code in second imageCompensation set to "In Control" gives you code in second image
Note the G42 line of codeNote the G42 line of code
