HughesTooling
First you have the stock set so there's 1mm on the top off the part so you will end up with 1mm + 2.5mm for the pocket with this setup.
Next in the op you have the bottom height set to Stock Bottom +1mm, you should have this set to Selected Contours and Offset 0mm.
Mark
Mark Hughes
Owner, Hughes Tooling
