07-23-2022
07:11 PM
- Mute
- Permalink
- Report
07-23-2022
07:11 PM
Hi ,
Machining a shaft and have added a pass through M00( Measure) so I can adjust my finish cut if needed. I make my adjustments on machine control, cycle start. the size still the same. I notice in the post it doesn't call the tool for the finish cycle. It starts where it left off. Is there away to make you adjustment then run finish cycle in the Step up in fusion 360.
Fusion
