leo.castellon
in reply to: Fabaaa
Have you tried using templates? Right click on a toolpath that works well for your part and near the bottom there is an option called " save as template".  Save the template to a folder with a name for your family of parts, or whatever makes sense to you.  Then on new part, set up your part, then right click on your setup, and go near the top and use "create from template" . So basically it is using your proven toolpaths and you are just applying them to your new geometry. I am not aware of anything that is more "automatic".
LeoC
