I've never milled in wood, but I'm kinda surprised that doesn't happen all the time, if your tool is anything but supersharp. At the first radius, with conventional, you're just "pulling" in the grain direction, but at the other two,
you're basically ripping the wood out of the stock. A change to climb milling wouldn't change that fact (?), or maybe some wood milling wizard could chime in here? I know there's a lot of you out there. :slightly_smiling_face:
/David
