programming2C78B
in reply to: sjj530
You can still finish pass with Depths enabled, I recommend 1x tool Dia for now, and play around with 2-3x. You can do repeat finish pass if youre REALLY worried about the "Stepped" look you may get with your tool deflection.
Please click "Accept Solution" if what I wrote solved your issue!
