brekmiller
in reply to: a.laasW8M6T
This is a known bug (CAM-34965) with machine simulation.  If you have two 3+2 toolpaths in a row and both have the same orientation (rotary axis values), then the second 3+2 toolpath is incorrectly simulated with the rotary axes set to zero.
The bug is that machine simulation resets the rotary axes back to zero after every 3+2 toolpath if your post processor script calls cancelRotation().  Normally this is ok because for the next 3+2 toolpath, your script will call setRotation().  However, many post processor scripts don't call setRotation() if the rotary angles don't change between 3+2 toolpaths.
This bug was fixed back on April 5.  The fix should be available in the next release of Fusion.
Brek Miller
Software Engineer
