rlaury
464 Views, 9 Replies
Giving up on engraving in Fusion.
I have spent the last 2 day trying to get this font to extrude. It shouldn't be this hard. It's a font that I have to use for my customer.I can place the font anywhere i want, resize it all of that process is normal. but when I try to extrude it .015" below the surface Fusion 360 can't find it. I have tried .TTF and .otf  I have it installed in Windows 10. It works on Inkscape.   If anyone has any suggestion please let me know
Helvetica roman 55 .ttf
Helvetica roman.otf
seth.madore
in reply to: rlaury
Please share your Fusion file so we can see what you're dealing with.
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
rlaury
in reply to: seth.madore
Seth: Thanks for looking in to this. I have tried everything I know. Please let me know what I'm doing wrong.
PatrickPowers-CGS
in reply to: rlaury
It really should be easier. I understand your frustration.
seth.madore
in reply to: rlaury
When creating text for the purpose of engraving, there's no need to actually perform an extrusion to the model. All one needs to do is create text and select "Engrave". Now, if there is a customer need to machine to a specific depth, then yes, one must Extrude into the model. To do so, one must select the text (in Sketch mode) and select "Explode Text".
Seth Madore
HughesTooling
@seth.madore  Do you have the Helvetica roman font installed? If you don't and from the look of your file you don't, Fusion defaults back to Arial. The Helvetica font seems to be only free for personal use so I haven't downloaded it to test.
Mark Hughes
Owner, Hughes Tooling
rlaury
in reply to: HughesTooling
Hi:
Thanks for the response. I do have the Helvetica 55 font installed.
HughesTooling
in reply to: rlaury
@rlaury  My reply was to @seth.madore I think his sample file is using Ariel. There seem to be quite a few fonts that Fusion will not work with, really then your only workaround is to use something like Inkscape to create an SVG.
Mark
Mark Hughes
seth.madore
Ahh, thanks for pointing that out, Mark. No, I did not have Helvetica installed. I'll try it again this morning
Seth Madore
seth.madore
in reply to: rlaury
@rlaury wrote:
Hi:
Where did you find the Helvetica font, as I'm seeing multiple sources for them. Did you select .ttf or .otf?
I did find one that would show up in Fusion, but it's failing when it comes to Engrave or even Extrude
Seth Madore
