engineguy
in reply to: jscott6SWZG
@jscott6SWZG
You are absolutely allowed to upload files with the free version, who told you that ??
Go to :-
File > Export > Select f3d format > Save to a location on your computer > Then attach to your reply using the "Attachments" facility below your reply box.
If your list of format options does not have f3d then you will likely have f3z option, this will probably be because you have something linked to your Fusion file like for example a Machine, if so then select the f3z option and upload that.
It is easier for others if you can upload an f3d file so try it if you can :slightly_smiling_face: :slightly_smiling_face:
