engineguy
in reply to: jz79
@jz79
Hmmm, this as far as I know has been around for quite a while.
It may be that the assumption is that if you are using the Default "Selected Contour"  option then the user already knows where the Bottom height is, however I suppose a confirmation would be nice, especially if a minus or plus value has also been used, think it does need a "fix" :slightly_smiling_face:
It seems to work fine with all the other selections :slightly_smiling_face:
