Hi @dtompkins93
Currently the post is set to output only for first cycle, It seems like you need output cycle for each hole then the post needs to be edited as shown, find for the below codes it should be somewhere in 769
  if (isFirstCyclePoint()) {
    repositionToCycleClearance(cycle, x, y, z);
you have to change the isFirstCyclePoint to true
  if (true) {
Save the post and test it
Boopathi Sivakumar
Senior Technology Consultant
