engineguy
in reply to: tjtalma
@tjtalma
You appear to have created your Model in the "Y axis up" mode and then in Manufacture you have selected the "Model Orientation" option in your Setup, this means that the top face of the Model is in the Y axis and not the Z so that is likely where the Z axis error is coming from.
Have a look at the attached file settings for the Setup.
For future reference if you want to be able to use the default "Model Orientation" then you may be best going to your "Preferences" and changing to the "Z Axis up" option.
You had 11 NC Programs where I think that you kept trying to Post multiple times, to avoid having all those NC Programs cluttering up your space then delete all but the original one and then Right click on the original one and then select "Edit" to open it and re-post, you will then only have a single NC Program :slightly_smiling_face:
