- Mute
- Permalink
- Report
Invalid Toolpath Warning after double clicking valid toolpath
I'm finding that Fusion 360 is fussy about letting you edit an existing tool path!
After setting up a toolpath operation (F360 >CAM >2D/3D >any milling operation like 2D contour, etc) and going back to edit that tool path you'll often run into one of two problems.
Problem 1 - Trying to bring up the 2D or 3D toolpath operation is hard. you can't count on clicking on the small operation icon. You also can't count on clicking on the toolpath text name as Fusion 360 gets confused if you are just selecting it, renaming it or wanting to edit it.
Problem 2 - If you do get a rename option and click out that will usually trigger the red ! exclamation icon which will bump over the tool icon and toolpath name. If you go to the toolpath palette and click OK the red icon in the toolpath operation will go away.
Not sure what is triggering this, it is possible I'm creating crappy toolpath operations as I'm just learning this part, but the inconsistent UI feedback isn't helping!
Anyone else noticing this or have tips on how to consistently edit toolpaths without this hassle?
Seems like a right mouse button click on a toolpath under setup should give you the same options regardless if the toolpath palette is open or not. Worse if it is open you get 3 options for stock selection, predrill operation and entry operation that all fail to work.
For CAM users being able to quickly select a toolpath operation, edit it, delete it or rename it should be the first 3 options.
Fusion
