info5APCW
in reply to: seth.madore
Thank You.  this worked great, and the added '0' in the other single digit M codes is completely acceptable.
I had one more question on this same post processor.
The M110 is output at the end of a toolpath (right before the next N number or tool change)
I'm not sure what the reasoning behind this is besides maybe being able to do a tool change outside the normal turret home position.
Problem is, there really needs to be an M110 right after a tool change at the beginning of the toolpath.
Many times while getting a part running smoothly, you need to restart the program at a specific N number to redo a finish pass, etc...  Though if you forget to go to MDI and manually input an M110, chances are you will have an interference alarm (at least I do).
I currently manually insert an M110 after ever tool change.  A bit tedious, but necessary.
Any way to get the Doosan Mill Turn post to do this.
Thanks again.
