- Mute
- Permalink
- Report
Been searching this post processor to find where it outputs the M1 code before the next tool change.
What I'm trying to do is change the output from M1 to M01. This may or may not be possible due to the logic they use to output these codes.
Reason for this is with the new Doosan interface, when you search through a program in edit mode, there is no easy way to jump from tool change to tool change with a press of a single button. I have found that if I change the M1 to M01, I can search the M01 (which it remembers every time you go into edit), and this quickly jumps to the beginning of each tool change. Plus you can quickly search up and down. Makes jumping through a program very quick.
Can't use the M1 code because of the M110 codes that it stops on as well. But M01 works great.
Thanks!
Fusion
