You are now using a 6mm endmill, but you have Rest Machining turned on, with 6mm defined. What you need is:
1: Pocket toolpath, 6mm endmill
2) Pocket toolpath, 3.175mm (.125) endmill, Rest Machining turned on, 6mm endmill defined as the "Tool Diameter"
Seth Madore
